ActualFactuals
- Messages
- 1
- Reaction score
- 0
I'm brand-new to building carts, so if I have bad questions please bear with me.
I'm trying to build a one-seater off road/go cart hybrid with a 670 V-Twin Predator engine from Harbor Freight. I'm probably going to mount the engine on a swing arm right above the rear axle to make the rear suspension easier.
My questions are:
- How should the drive train actually be configured? I know that most people mount a torque converter to the output shaft on the engine but how where does the train move from there? I've seen a few videos about what I'm trying to do and it seems that it's straight to the live axle from there.
- Following that, how could I get a reverse gear (I'm pretty sure torque converters are not transmissions).
- What torque converter, if the recommended drive train requires one, should I use? The beefiest torque converter I have seen is a 40-series which is only rated up to 18hp (the engine I want to use is 22 hp).
- What transmission should I use to get a forward and reverse gear? Preferably the more speeds the better, but I'm only worried about forward and reverse. Secondly, what transmission would be able to handle the output of the engine?
Thank you very much for any recommendations that are made.
My questions are:
