jvandyke
Wow, I'm confused.
Purchased rolling frame go kart. 14" overall diameter rear wheels, 72 tooth sprocket, #40 (I just recently figured out) came with chain to match.
Had a 5hp Tecumseh we hoped to resurrect and use.
Purchased a Max Torque clutch for it but then figured out the 12 tooth sprocket on the clutch was for a #35 chain.
Emailedd Jim D. at Max Torque about what to do. He thinks go TC
His words:
To make the switch all you need is a drum and sprocket --10tooth #41 sprocket and the drum most likely for a 3/4" crankshaft which is 4 horse power and above up to 7 hp, 8hp is a 1" crankshaft. You can look on the internet and see what a complete clutch cost (e-bay) and you can call Comet Kart Sales 317-462-3414 and order just the drum and sprocket from them.
So, help me figure out my best move. We just want a little kart to bomb around in and tinker with, throwing $200 more at it probably will stall the project but if that what it takes so be it.
I'm really lost now.
TIA!!!
His words:
TIA!!!
