R97 planning..... something, not sure what
migel101
south america
nice welder!
people say stacked dimes this, stacked dimes that, yeesh, I just do a slow pass, grind it down, and if I cant brake it im happy :D
gokart14
Nebraska
i usally do circle motion but lately i have been filling in gaps in the metal got pretty good.
the problem i have is some days i can do slow circles and get a nice bead, but at other times(same metal . same temp) i have to go extremly fast or else burn through that gets me mad
r97
Measure twice cut once
Massachusetts, USA
nice welder!
the stack of dimes itself doesn't make the weld stronger, i can make a weld that looks like just a big old bead of metal that can be super strong. that said the stack of dimes looks good, and if you get the dimes its a good indication your gun movement is dialed in correctly.
yeah, its a great little welder, can't wait until Tuesday so i can get a gas bottle!
there seem many differant methods
straight
zig zag
malf moons
circles
ovals
i like the ovals or circles
yeah there are lots of methods!i usually stick with the circles, but i like to toss around other methods too, but in the end they all seam to do about the same thing.
I zig zag. Geting better but need to practice going around round pipe better.
yeah pipe is hard to get continous bead
:iagree: pipe, especially small dia pipe can be a pain, some days its easy, some days your beads just wander wayyyy off.
i hate burn through....
TorqueRanger
Tubing is the best to learn how to weld.. I take regular tests on my welds and i take pride in my welds.. Doing a $hitty weld because of laziness is a complete waste of time and effort and no pride in your work ( Do it right the first time)..
r97
Massachusetts, USA
just ordered a few things:
-POR-15 semi-gloss black starter kit to line my tank with.
-fuel filter for mini bike
-taper adapter for drill press
hopefully with that stuff i can get the drill press an the mini bike up and running! :thumbsup:
later this week if i can convince mom to drive me i should be able to pickup either a 40, 60 or maybe an 80cf 75/25 shielding gas bottle depending on what the student discount is. need to get some solid wire too. then, maybe over the weekend i can get some steel from the steel yard for a few of my projects. most important is the welding cart, then the welding table, and bench grinder stand if i have enough $$.
_______________________________________________
After all that i can hopefully have the mini running, and get to work on the go kart in the summer. my plan for the go kart is to make it a race style kart, and i plan to use my subie EX17 w/ a cent clutch. so i need to get some steel, a cent clutch, a sprocket, an axle, and a new tire/rim/hub assembly. i'm going to make the frame from 1 1/4" sq tube with a 14ga to 1/8" wall
then later in the summer, or maybe into the fall if i can't gather enough $ i'm hoping to make a replica of a Rupp enduro with a torque converter and 7hp Tecumseh flatty, making whatever i can from scratch of course! :D. like this, should be fun on some trails!
