r97
Measure twice cut once
___________________________________________________
I THOUGHT YOU WERE BUILDING A SIDE WINDER!?
i was planning on the sidewinder, i still really want to build it, but its just getting more and more expensive (i was also having a lot of trouble locating an engine...), so that project will probably be put into "storage".
maybe once i get a real job i can think about it again.
NEW WELDER?
instead i'm hoping to save up for a larger MIG welder!
MIG welders are expensive! so are gas bottles! anyway i'm searching for the best deal on something that can MIG weld 1/4" steel and have the option to do some aluminum work in the future.
not sure what to get, the ideal machine is a Hobart Handler 210, but that would be my one b-day present, and i would be nearly broke, or in debt..... i will see how much i can save up in the next month or so, then possible sell my old welder to get a gas bottle.
maybe you guys have some suggestions, or ideas of different tools to get.
_____________________________________________________
NEW PROJECTS?
if i do get a welder i will probably be looking at building a welding cart, bench grinder stand, and maybe a table if can afford it after i buy the welder.
after that i'm thinking another mini bike, either a Honda trail 70 kinda thing to ride on the trails with, or maybe a mini cafe racer style bike.
another option would be to re-do the go kart so it doesn't flip over so easily.... hopefully not to expensive since i would have most parts already.
THE MINI-MINI BIKE:
some of you may be curious about the mini-mini bike.
basically i entered it in the science fair, won, was told i could not ride it, went to he next fair, then got disqualified because it was to dangerous (they couldn't have determined that 2 or 3 months ago huh?)
hopefully i can get the starting method figured out for the mini bike, then get the gas tank cleaned out, and see if it all works!
LINKS AND PICTURES:
Honda mini trail,
welding cart (yeah, i got bored and made a sketch-up
best welder i could possibly get, very (very!!!!!!) expensive though...
http://www.northerntool.com/shop/tools/product_200392663_200392663
what i was building, but it's just too expensive... (sidewinder),
http://www.edge.au.com/Categories/Sidewinder
Mini-mini bike, needs a few things before test run,
go kart to either be modified a good bit, or have a new frame built for it (looks awesome, but handling is scary, its also very unstable...),
anyway, tips, suggestions, or opinions are welcome!
NEW WELDER?
NEW PROJECTS?
THE MINI-MINI BIKE:
.hopefully i can get the starting method figured out for the mini bike, then get the gas tank cleaned out, and see if it all works!
LINKS AND PICTURES:
Honda mini trail,
