Question on setting up Torque converter system
shepo1
Hi.. I have a kart that currently has a Clutch type system with jack shaft. I want to convert to a torque converter but have a couple questions. I have added some drawings of what i have and my question is does it matter how the DRIVEN pulley mounts to the jack shaft?? Does the unit have to rotate counter clockwise to function? Just trying to figure out the geometry of it all and make sure I don't have to do any major modifications.. Right now it looks like I can just replace the Clutch and pulley and leave the rest alone.
Thanks..
In case you cant see the pic... My current system is a 3" OD Centrifugal Clutch ( belt type) that drives a 6" OD pulley mounted to a jack shaft, then I have a 12T sprocket driving a 48T gear mounted to the wheel. I plan on using a 6" driven unit My tires are 13" turf type tires.. plan on trying to get more top speed out of it.. Mostly use on pavement and grass.. no major off roading..
Thanks.
Hi, you need to get rid of the clutch and pulley;
that's where the Torque converter will be afterwards.
it'll replace the clutch and pulley (being a clutch and pulley itself)
It DOES matter which way the driven mounts to the jackshaft..
a series 30 is always outboard because of the asymmetric belt.
a series 40 can run either way;
normally it runs inboard;
but if the driven pulley spring is changed to a reverse wound spring, it can run outboard as well.
shepo1
I may have found part of the answer to my question.. but then that leads to some new ones.. LOL..
I can see if I go with a Asymmetric system, that I will be forced due to the belt shape to mount the Driven pulley in a specific way.. But if I go Symmetric, then i could mount it either way.. so that it comes back to the same question.. does it matter which way you mount it...
Also.. I was thinking of the comet 30 series but that is Asymmetric.. could i go with the 20 series? or is that to weak of a system..
Thanks again.. in advance..
shepo1
@ itsid Hi.. sorry i posted my previous post before seeing your reply... Yes, I plan on just replacing both parts like you suggested.. But was hoping to be able to use the same Jackshaft and such and keep the geometry the same so all the mounting bolts and such will still be viable. Would a series 20 work? or is the series 40 the only that can be mounted either way.. Or if I go with a Series 30... can i still mount it such that the mechanical parts are inboard to the jackshaft ? like in the pic? not sure on how the driven is held in place on the jackshaft i guess.
also, any advantage to symmetrical vs Asymmetrical ?
Thanks again..
if you find a series 20 you can use a series 20 .. (it's rated for as much HP as the series 30)
BUT the series 20 as well as the series 40 DO NOT have overdrive!
overdrive can only be achieved with the asymmetric set up.
I think you can run a series 30 though;
outboard only referes to the position relative to the engine;
AFAIK it allows the jackshaft to be flipped.
(I'll check that and report back)
shepo1
Thanks... i appreciate it... Would like to run a 30 then if i can ...
Soooo
I checked and I do not see any reason why it wouldn't work;
just make sure there is a belt for your desired center/center distance (basically center/center PTO - JS distance you can measure right now without having a TC ;)
the jackshaft passes all the way through and the cam - backplate distance and position is fixed.
So to my best knowledge; it doesn't make a difference at which side the JS is mounted as long as the position of the driven is unchanged (relative to the driver).
BUT (oh no.. there has to be one all the time, doesn't it?)
make sure you have enough room on your jackshaft to mount the driven pulley;
it's much wider than a conventional single ratio pulley;
so make sure it doesn't interfere with a bearing or something.
Half-breeder
"Edit" button removed
A pic of your current setup would be pretty helpful for a positive answer... but Sid is 99% correct w/ his referrals/replies(if enough details are given).
shepo1
Thanks Sid and Half,,.. YA so.. i was looking it over last night.. and I can see where I may run into some issues getting it all lined up because my jack shaft Bracket/support unit maybe to long with not enough shaft Exposed . The overall length of the shaft is 7" with only enough sticking out on each end to mount the sprocket and the pulley ( about 1 inch on each side. Not enough to make any adjustment per say.. Like you said the width of the Driven is wider then standard pulley. Current set up every thing lines up. I can slide the whole Jack Shaft assembly left and right a little.. but I have to make sure the sprocket for the chain lines up with the Gear on the wheel first. So then the Pulley on the jack shaft has to line up with the clutch on the motor kinda by default. I dont have any shaft to work with to move the pulley in relation to the Shaft assembly left or right. I can move the motor a little though so that is what i have to do to get the Belt lined up in current set up. So if the new Driven is much wider, then I will have to move the motor to the right even more if I want to use the current Jackshaft unit otherwise I don't think i will get the Drive and Driven to line up. ( cant ever be as easy as we think can it)
So Issues at present.
1) does current jack shaft even have enough shaft sticking out to properly support the new DRIVEN pulley. If not I have to get a longer shaft, or cut off some of the current jack shaft support bracket to expose more of the shaft
2) Once mounted.. can I get the Drive and Driven to line up. If not .. options are
A) Try to remount motor further to the right
B) Modify Jack Shaft assembly so that It will expose more shaft and let me mount the Driven Pulley further to the left.. ( might need to do this anyway due to the first issue of mounting the driven pulley.
anyway... I think i got some ideas.. thanks for the input and advise.. I think i got some measuring and thinking to do..
I don't have much room to remount the motor with out major fabrication.. so modifying the jack shaft right now seems to be the way to go..
shepo1
One more question.. do anybody know the dimension from the back of the Drive pulley to the center line of the belt.. Trying to figure out my jack shaft length that i will need to accommodate the Driven pulley..Thanks
shepo1
well.. I just ordered the parts.. will see what happens..Im sure if needed I can move the motor mounting location with minimal effort.. so I should be able to make it work.. I ordered a new jackshaft.. mine was only about 7 inches long, so that wouldn't have been enough for the new DRIVEN pulley to mount on to.. So I got a 10" one, so that should give me a extra 3" or so.. Will get some pics of the before and after.. for anyone else that might be considering doing this.
Thanks
Thanks
Great :thumbsup:
shepo1
Good afternoon.. We have success !!! :thumbsup: I have included some pics of what we had to do for anyone that might have some interest in converting to this.. Main issue we ran into was that the Jack-shaft bearing support unit was just slightly to long to allow me to move the Driven unit as far as i needed to to the left of the motor so i could line up the belt, but yet also still line up the chain side. Hmmm .. It looked good on paper.. but once i got the new DRIVE unit on the motor, i found that it protruded out farther then the old Clutch unit. Options were to move the motor to the right but that would take creating new adjustable mounting holes and i didn't really have any way to do this easily.. Motor mounting didn't really have any side to side adjustment.. just front to back. So what i ended up doing was to elongate the holes on the Jack shaft support unit so i could slide it farther to the left.. and then flip the 12T sprocket around and use just a small spacer so the chain had clearance. this gave me just the right amount of movement to the left that i could just barely get everything lined up.. LOL.. Anyway.. all in all not to bad.. Seem to get up and go pretty good.. even with me on it and i weigh 270.. so.. ya.. thanks for all the help :cheers2:.. here are some pics for your viewing pleasure.. 1-5 is the original set up 6 - 10 is after i mounted the new Driven unit and figure out how to make it all line up.
shepo1
One last follow up.. we got 45 MPH out of it with this mod..( used iPhone speedo ap) before it was probably at about 15 ish. i guess.. so ya..she cooks along now LOL..
Awesome, glad you figured it out.
There's an old proverb: "Necessity is the mother of invention", which means, if you need something bad enough, you'll figure out a way to make it work; good to see your mind working :thumbsup:
Oh & thanks for the install explanation, I'm sure it will come in handy...
