Hi.. I have a kart that currently has a Clutch type system with jack shaft. I want to convert to a torque converter but have a couple questions. I have added some drawings of what i have and my question is does it matter how the DRIVEN pulley mounts to the jack shaft?? Does the unit have to rotate counter clockwise to function? Just trying to figure out the geometry of it all and make sure I don't have to do any major modifications.. Right now it looks like I can just replace the Clutch and pulley and leave the rest alone.
Thanks..
In case you cant see the pic... My current system is a 3" OD Centrifugal Clutch ( belt type) that drives a 6" OD pulley mounted to a jack shaft, then I have a 12T sprocket driving a 48T gear mounted to the wheel. I plan on using a 6" driven unit My tires are 13" turf type tires.. plan on trying to get more top speed out of it.. Mostly use on pavement and grass.. no major off roading..
Thanks.
Thanks..
Thanks.
hang in there.... Someone who has done this will chime in soon......
.. here are some pics for your viewing pleasure.. 1-5 is the original set up 6 - 10 is after i mounted the new Driven unit and figure out how to make it all line up.
