What do I need to do to get this combo to work? Its an OEM B&S intake with a PZ22. Should I grind on the area holding the square nuts in so I can take them out and use regular bolts? Thats what it looks like I need to do but I want other opinions
Theres nothing I can weld to it, the carb is aluminum. I'm going to have to remove the nuts and trim the "ears" that held them in so it can bolt up to the intake. All the bolt holes line up perfectly
Yeah they're pretty short but it works for me. I got mine to fit the way it needed to. The Studz Racing intake would've worked without modification but they were sold out, its a little bit longer than the OEM intake too which would work better for you. I dont understand the difference in intake length for different hp/tq
Longer intake tubes (and runners) create more torque in the low/midrange because the air has more of a chance to straighten out for a more laminar flow. Even building an inake tube to go between the filter and carb (like a car) will help accomplish that also.
I restored the side cover that I found laying out in the elements. Its waiting on two reproduction B&S decals to finish it up too. It'll look good on my ripsnorter
Lol i got mine before you! Just gotta get the gear and im building a mini sandrail style go kart im going to make a thread for it because im tryin to stay on topic. But i will be making my briggs intake one i learn a little
