PWM Motor controller
kibble
I banned myself
never been a fan of pics. ive been raised on the atmega chips. around 4 bucks a pop and you can get away with a homemade programmer. the ide is also free
I've thought about Atmega's too, it's really difficult getting to learn stuff like this by yourself though. I don't personally know anyone else that's into electronics like this, other than one of my uncles, but he lives kinda far away and he doesn't do as much as he used to. All my friends are into other things so pretty much everything I know, I've learned by myself.
Scumm
So, back to before the hijack... Kibble your project is really what i've been hunting. The closest controller Ive found is http://www.dimensionengineering.com/Sabertooth2X25.htm
but the rating is too low for my application. After finding 2 drills my landlord threw out w/ 1/4 HP motors, I've been thinking about making a kick *** radio controlled vehicle.
kibble
I banned myself
I need to start designing the circuit board for the controller. So far I have been collecting some components that I will need. I still need more diodes but I went to the store to look for them and they didn't have them.
I need to get some connectors too.
kibble
I banned myself
Here's some progress. I started designing the board.
zabac70
:thumbsup: Is there enough space for heat sinks (I hope this is a correct term) on sides of the board. You should consider some kind of forced cooling for that number of mosfets.
kibble
I banned myself
The enclosure I'm using, the amp casing, is the heatsink and, yes, I was going to use a small fan to cool the inside of the case too.
kibble
I banned myself
Thanks! Here's some more. The stuff in the middle is the PWM part. I removed the zener diode and 1/2W resistor along with a few other things and am using a 3A, switching voltage regulator instead as I will be powering a few other things off of the 5V supply.
I added a connector that will be going to a 6 pin DIN connector on the case. The throttle and brake will connect to that and I may have a pin or two left for other things later on.
I will be making another sub-board that will monitor current and will have an LED bar graph to show battery voltage.
I'm still tweaking things here and there on the board so this is not the final design.
zabac70
:thumbsup: When you finish it and test it with some load , will you post final schematics and board print (possibly parts list)?
ZnsaneRyder
Crazy Guy on a Bicycle
FL
That's bad azz! You are making a new PCB and everything!!!
Sure beats using the RadioShack veroboards for sure!
kibble
I banned myself
Yeah, once I make sure it works properly.
LOL, I stopped using those radioshack boards forever ago. It's really not that hard to make your own boards with the photo etching method.
kibble
I banned myself
Here's a pic of a partial collection of some of the parts I'll be using. Unfortunately, progress is slow at the moment due to lack of funds.... :(
kibble
I banned myself
Finally made some progress today! :D
Got done etching the circuit boards that I'll be using. I will make another one that will monitor current but, that one hasn't been designed yet.
The big board is the main power board. the two smaller boards are; 5V regulator and a bar graph volt meter that I will use to monitor battery.
Here's some pics for your viewing pleasure....
truesprocket
Central Canadian
toronto canada
looking to build a gocart size 12 volt motor controller,
Hi I'm looking to find scematic's to build a motor controller for a 12 volt golfcart style motor any help or site's you could point me to would be fantastic , I'm hoping to run it off 4 6volt deepcells, that'll depend on how long it lasts & I'd like to be able to switch to 24volts & push that through the 12volt motor, safe to do ? anybody ?
zabac70
Cool stuff ... You can "push" doubled voltage trough your motor , but you have to be careful with power (Amps). As for schematic's , google is your friend , but I suggest Yahoo group : OSMC (open source motor controller) - you need to sign in. However , you need to do a bit of research first , to be sure what you want and need (controller wise) and have a look see on e-bay or wherever to check if something already exists that will suit you for the purpose - some of that stuff is really cheap and it is (often) not worth bothering to make one yourself (components you'll need , time and aggravation ...). Best of luck with your project !
