Putting the pieces back together help...
neebles
New Project
Illinois
Ok so, I took off the carb, stock air filter about a month or so ago, and since this is really my first time doing it, im not sure how it goes back together....:furious2:
Anyway, if you could just look at this picture and tell me if the order is correct, some of the confusion is coming in because i am adding a manifold spacer....
Im thinking it goes Engine, Carb Spacer, manifold spacer, gasket, I dont know where this little Metal gasket looking thing goes, Carb then airfilter. I guess im more confused in regards to the manifold gasket, and the metal gasket thing that came off the carb :mad2:
And im getting a new air filter set up in about a week, so the stock one is going to be gone...
jr dragster T
Cold place
Yes, That order is correct. I don't believe you need the stock nylon spacer with that aluminum pulse fitting spacer though.
neebles
New Project
Illinois
I didnt think so either, but Russell at NR said I did.....Maybe I will get another gasket or something and leave it off just to see what happens....
