Missed how this got to flywheel removals, but you never put a torch to a flywheel, there's a heat-sensitive main bearing right there!
EDIT: To drive the wheel off the axle AFTER removing or loosening everything holding it on, I'd suggest a heavy piece of some scrap angle iron and a BFH. So, 3/16" minimum thickness angle iron would work well, at least as big as the O.D. of the axle, and just a few inches long is all you'd need to make a great tool.
Lay the angle over the axle right up against the inside of the wheel (or the collar), and wrap a few turns of tape (I like electrical tape) around the angle/axle to keep the angle from jumping off.
Lay a heavy hammer (I have 3# and 4# mini-sledges) on the axle so you can sort of slide it along the axle, so you don't keep beating up the axle as you swing, and start swinging. Angle will make good contact in 2 lines with wheel (or collar). You can spin the angle around the axle evenly as you go if you just hold it on without using the tape.
