Kenny_McCormic
Kartless....
If it hasnt been done already disable the governor. And replace the muffler with a much bigger one or a foot of water pipe(exhaust port is threaded)
Yea, give the rollers a thick coat of bearing grease.
Thanks again for all the kind words folks!
I forgot to tell you that I tore it back apart and greased the rollers and ramps. It eliminated an issue I had when the clutch got warm. It would engage a little earlier than normal. It wasn't that noticable, but since I lubed up the clutch, its gone.
Been enjoying the Dingo almost every night at some local schoolyards. Days are getting shorter, though. Looking forward to some wrenchin'.
When you tear it down check the welds. Manco doesnt make the best welds, I rewelded my frame because a few welds had cracked and were very minimally welded(full length of joint wast welded, both sides not welded).
Hey Fast Eddie, "You owe me MONEY", (Paul Newman) Anyhoo, nice kart! Is that a Dingo seat or aftermarket one? It looks alot more comfy then my plastic one. What does it measure from the outsides side to side? I have some room to spare for a new seat as this one doesn't fit my butt to good. I'm 6'4" and 240lbs. Thanx in advance...
Also, what kind of TC do you have. That's a long cover like mine. 11" centers on mine roughly. From the owner of Max Torque, he said murray mixed matched mine with a comet and it equals a 20 series. Just curious as to what your is...
Disabling the gov will make a real difference if you give it room to wind out.
Neighbors are starting to complain, though.
