Project: Briggs 3.5 (Don't eat while reading)
gocartkid
Bad Attitude
CT
And it's hard to tell, but does the rod contact the side of the block? You can clearance that, I've seen it done.
oscaryu1
Mike Clements... that guy is well, let's just say one of the "gods" of racing. Known worldwide. Mike Clements and his racing family, 50+ years of experience.
Yes, right there the block is VERY thin. I drilling right around there for a pulse port on 3HP, it was literally 1/16-1/8" thick.
I was using a .590 Wiseco Piston, and a stock length Raptor rod.
This was DIRECTLY from Mike's post:
http://karting.4cycle.com/showthread.php?t=57433&highlight=horse
Notice how he says 3HP. I took one of its block apart... and guess what? Wrong.
Emailed him, he said it "might've been the 3.5HP block". Now this... again, BS! Proven wrong over and over. 50 years my :censored:
I'm probably overreacting, but what are you supposed to do when you're $150 down and a project has failed?
kibble
I banned myself
ay jerry
is that a scrub brake made outa plumbing?
It's not a scrub brake, it was supposed to be an adapter for the intake.
:toetap05: No need to be so harsh Jr. Geez do I have to moderate you kids too? :arf: :roflol:
jr dragster T
Cold place
I try to be nice. But he CLEARLY stated it was a intake AND the kart already had brakes in the pic. And trust me it could get ALOT nastier but let's not go there.
sayre315
Rupp enduro
Oklahoma
haha this is funny
i know he clearly stated that but it kinda fit the tire perfectly and i think if i ever find a crap load of plumbing pieces im gonna make a kart outa then :)
gocartkid
Bad Attitude
CT
Oh, that area must be thinner on a 3/3.5 block than on a 5. And I'm with ya, I'd be pissed too. :mad2:
oscaryu1
$150 :'( :'(
What?! No cry face?! :(
The shortest rod they make for the 5HP Briggs is the 3.870... unless you wanna go custom... and a .005 difference doesn't do much.
gocartkid
Bad Attitude
CT
$150 :'( :'(
Hmm....guess that isn't an option either. How determined are you to make this work? I ask because you could use extra head gaskets and if you do the math and do some thinking you might be able to come out ahead. Using extra gaskets would solve the piston clearance issue, and with the head higher up you will be able to use a much higher lift cam. See where I'm going with this? It all depends on how much you want it. I would clearance the block and then take a good look at it. If you feel unsafe with it that way (too thin) then I'd do what Kenny said and make a "box" that extended out of the block right there.
But then again,how much hp will this thing end up putting out? Is it worth the trouble over a decently prepped 5?
oscaryu1
That's a brilliant idea... but is the head gasket itself supposed to keep the rings in? These 3.5HP head gaskets are super rare. There aren't many on eBay that I know of that fit...
I dunno what I'll do. Might call Carlson Motorsports and see if they sell a cast iron sleeve... hone it some more and tap it in.
