I don't usually use the power jet. I cap off the circuit and try to make sure the main jet provides enough fuel alone.
Can you explain what you mean by you "gravity feed them where they are supposed to be at"?
Gravity feed the carb? Or gravity feed the power jet and source the fuel from somewhere else besides the bowl?
I only use the inlet for the fuel line in the regular spot. And gravity feed equals no fuel pump so tank above carburetors so it will flow as needed.
---------- Post added at 04:46 PM ---------- Previous post was at 04:44 PM ----------
I had a regular pump in my minibike and it pushed past the needle. If you were sitting still it would leak out the overflow hose.
The pump was the standard one used on race karts. The round plastic black Honda ones.
