Preditor 212 install
fasteddie
My and my boy just picked up a backyard offroad.cheap gocart . Can we install a Preditor 212 will little or no problems?
Wow, that threw me. There's a Fast Eddie on here already. Well- welcome to the forum!
Engine install should be fairly simple. What engine is on there now?
Then it should be straightforward. I believe the mounting bolt pattern is the same, and so should shaft size. Be prepared to alter the throttle arrangement, as well as chain length and sprocket alignment. While the footprint should be the same, the ouput shaft will very likely be in a different position.
fasteddie
I just started to read some other post and I see they put on different air filter and exhaust. What kind and where to get them from.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I'd go with the new engine personally.. but that's just my $0.02. I was able to remove a 6.5 HP and throw on a 420cc Predator with NO adjustment to the chain, and such an easy install with a few new holes drilled in to the frame. In a couple hours, with some skills, you can have it running in no time. These engines are, in my opinion, the next best thing to an actual Honda. Relatively cheap and reliable.
The throttle adjustment wasn't too hard. Of course, my neighbor helped me, and he's pretty good with that kind of stuff. But it's simple and straightforward. You can use any bicycle brake line for the throttle. You will want a few throttle stop screws and a way to hold the conduit in place. I used some zip ties and pulled em good with a pair of pliers. Writing about this makes me want to get the go kart back out on the road from collecting dust for 2 months. =p Good luck, and keep us posted.
fasteddie
I think a 420 will be way to much motor for us . The old 5 hp motor that's on it is a hand full .
tundrabeagle3
Ca
if the 5 hp briggs is running i would keep it on there. They are very easy to work on and cheap to mod. I had one on my hawg ty and went to a predator 212 and it felt less powerful than my 5 hp briggs. The briggs felt more torquey and all i did to it was put in a high flow intake and straight pipe exhuast. a 3/4 pipe will screw right in.
