predator timing key ?
pearl111
Baltimore, Maryland
Hi to all at DIY. I have a predator 212 with the gov. removed. I got The upgrade kit with tailpipe muffler air filter gas jet emu. tube and 8* timing key. I have installed the kit everything but the key. Been running the motor on mini bike and everything works fine. Question would be ok to install the 8* timing key with the original flywheel ? I don't run the motor hard wot all the time but a little sometimes.
I know that all you tube vids are not correct with what they show and say is ok to do. I saw vid. where someone installed the 8* key and put the original flywheel back on. Is this ok to do or bad idea?
Thanks to all for any help and thoughts.
I'd say w/o heavier springs that'd be okay..
BUT keep in mind that advancing the ignition timing not only brings you a bit more oomph on high rpms, it also takes that away from the low end sooo maybe you rather have the majority of torque down low if you don't run WOT all that much.
PS I'd say try a 4° key first.. but since you have that 8° key at hand...
I wouldn't, but it shouldn't harm the engine (again if you DO NOT install heavier valve springs)
GearHeadGarage
GearHeadGarage
Ohio
I have 3deg key. .038 jet. Header, air cleaner mod. Still have the governor, but not for long , as I also have a 22mm Mikuni to install with a GX Honda flywheel
I took my 301 and stuck an adjustable timing bracket on it. Cranked the timing to 32btdc. Everything else is stock. It really woke up some sleeping ponies. Still running the gov too.
With your gov removed I'd just be careful of the top end Rpm's.
GearHeadGarage
GearHeadGarage
Ohio
I also have a non hemi 212 with the mods you have , no key. And it runs fine at 38mph on good gas.
