pearl111
Hi to all at DIY. I have a predator 212 with the gov. removed. I got The upgrade kit with tailpipe muffler air filter gas jet emu. tube and 8* timing key. I have installed the kit everything but the key. Been running the motor on mini bike and everything works fine. Question would be ok to install the 8* timing key with the original flywheel ? I don't run the motor hard wot all the time but a little sometimes.
I know that all you tube vids are not correct with what they show and say is ok to do. I saw vid. where someone installed the 8* key and put the original flywheel back on. Is this ok to do or bad idea?
Thanks to all for any help and thoughts.
