Predator/Powerland 420 Throttle
aham2003
Cleveland, Tn
Anybody got any pictures or ideas of a throttle setup with the governor removed from a 420? They sell a pretty nice kit with a bronze butterfly like barrel and return spring that I have used several times on all the 212s Ive done.
I dont think on of these will work on a 420 though. Any pictures, diagrams or advice is appreciated.
aham2003
Cleveland, Tn
Can you still use the factory tank with that? I am thinking about just fabing up something with the hardware that comes off when i take off the governor.
gman3850
gilbert az
with the gx390/420s throttle being opposite of the 212s u can use the long governor arm as a throttle hookup
KartFab
Dallas, TX
you cant use the tank with the top plate. I was able to get something to not work so well on my kart using the stock linkages, basiacally:
  • cut the governor pivot so it cant hit anything on the inside
  • replace the thick spring with 1/8" tig filler rod
  • install return spring, attached to the arm.
  • cry because the pivot ratios are off
What I still need to do is adjust the amount of travel that the throttle lever has when I push on the gas pedal as of right now, there is too much travel, so even a light feathering of the pedal will be instant max throttle. If i adjust the tie in point by welding something on there, it will likely come into contact with the tank hmmmmmm......
$25 and a different gas tank setup seems like the easy thing to do now that I look back at it.
