Can you still use the factory tank with that? I am thinking about just fabing up something with the hardware that comes off when i take off the governor.
you cant use the tank with the top plate. I was able to get something to not work so well on my kart using the stock linkages, basiacally:
- cut the governor pivot so it cant hit anything on the inside
- replace the thick spring with 1/8" tig filler rod
- install return spring, attached to the arm.
- cry because the pivot ratios are off
What I still need to do is adjust the amount of travel that the throttle lever has when I push on the gas pedal as of right now, there is too much travel, so even a light feathering of the pedal will be instant max throttle. If i adjust the tie in point by welding something on there, it will likely come into contact with the tank hmmmmmm......
$25 and a different gas tank setup seems like the easy thing to do now that I look back at it.
