Predator Mods...
mindymogul
Mistress of Destruction
Land of Camo and Fireball
Alrighty then...
i can't seem to find a d^nm thing on the predator engines for anything with mods. what i've been trying to find is something for a coil to run my lights off from since they draw too much from the battery I have. im not sure if I should find a blown 8 or 13hp and pull the coil from those or if there's any mods out there to help my needs. any ideas?
mindymogul
where would I get a conversion kit? i can't find anything on ebay and gopowerports, gokartsua, and some of the other sites i checked don't have anything as far as I can see.
Well, see, there's the problem, AFAIK, no one makes a kit for the predator so, you would need a Honda GX clone (which the predator is not); there are kits everywhere for those...
Truth be told, you don't even need the entire kit, you only need the charging coil, magnetic pickups & somewhere to mount it but, as the pick ups are built into the flywheel... we're back to square one...
mindymogul
so in other words i'm better off to go with the 8hp (to keep it cheap as possible) and buy a whole new drive system? what if i milled out a sprocket and welded an add-on piece to the chain drive connected to the jackshaft? i could run a starter/generator on that couldn't i?
KartFab
Dallas, TX
hold on there one sec, i remember some dude did this on youtube
here it is https://www.youtube.com/watch?v=lZodC58L0Zc
not to get your hopes up, but his engine might have been an early one, IIRC the 'new' ones have a wonky crankshaft that wont accept the lifan/gx200 flyhweels. If i knew for sure that these puppies accepted electric start, i already would have set it up :-(
If you dont want to lay down the cash for a genuine honda, there are always the 'box stock clones' that are a gx200 exact clone that will take a honda flywheel and electric start setup (from what I am aware of).
DHC
Can you?.... oh yea! "Should' you?... it's on you! ANYTHING added to the drive system of a kart will 'rob' HP. Electrical's are very nice but over rated on a go kart (IMO) a simple battery that is recharged via wall socket at end of day is 1000X's a simpler fix (and usually cheaper). Electric start is VERY nice... but overrated for a kart.
mindymogul
well, it's not just that. this is a beast and it's actually running a modified snowblower drive system to allow for high torque at low gears and decent speed in the highs. (a lot like a 90s ford ranger 2.3l 5spd) but this thing is also run at night all the time. i'll get some pics of it when i can to show my dilemma.
