Predator crankshaft question
Lefturns75
Podunkville USA in the ozarks
Ok guys, maybe I am being too careful but I would like your opinion. I have a engine project I have been doing on and off and at times I will put the parts in a box and store them on a shelf until I start again. As I pulled the box off the shelf, I had forgotten I placed the crankshaft there and it made its way to the floor with a clang. It was wrapped in a shop towel and I have inspected it and found no dings, scratches and can't tell how it landed. My question is, would you use it or just get another?? It looks fine but it was about a 6 foot drop. If this was just a turd motor build, I figure I would use it but this one has lots of aftermarket parts in it. What's your opinion guys??
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Take it and have it X-rayed! Just kidding. That is a tough call. If you are spendoing a bunch of money on a nice motor it would suck if that has a tiny crack and then blows up everything.
I wonder if "magnaflux" I think it is called would help search for cracks. I think it is used for finding cracks on Cast iron engine heads not necesarily machined crank surfaces.
Zombient
Junkyard Derelict
Waco, Texas
Crank shafts are meant to take some stress. Depending on how far it fell and what it fell on, I'd say just give it a good inspection. Unless it fell on concrete, I'd doubt it would have cracked.
Lefturns75
Zom, it landed on the concrete shop floor. I have inspected this thing from every angle and I can't find a mark anywhere. I installed the stock rod and it spins freely as it should just to check. I was just worried that I might have caused a problem that won't show up until 7K. And No, I won't be using the stock rod while attempting 7K. I may just use this thing and close my eyes and hope for the best, chances are you are right, its just fine. Should I find a good crank on the cheap, I will replace this one.
Zombient
Junkyard Derelict
Waco, Texas
I think that a crank would crack or break before it would bend, they're cast aren't they? I think you'll be fine, just keep an eye on it!
I my self would not use it unless I could get it magnafluxed and checked for straightness. It would probably be cheaper to buy a new one though. So no! I would not use it. :censored: It only needs to be bent a few thousandths of an inch to really screw things up. This is just 30 some odd years experience building engines talking.
:useless:
Lefturns75
Thanks to all of you for your thoughts on this. Zom, I think you are right, this might be ok to use----for maybe a spare or a regular old rebuild. I will keep it around for that purpose. Denny makes a good point and I have found a new, unused crank I can pick up for $30. I think I will use that one just for some piece of mind. With the kind of luck I have, I don't mind the extra $$ if there is a chance I might destroy all the other parts with the old crank. Thanks for helping an old geezer make up his mind!!!
