Little background info: engine is a Predator 212cc 60363 engine with some light mods done to it. 18lb valve springs, removed governor, pod filter, and I put a real small motorcycle muffler on it because it was too loud for the neighbors with it being straight piped. Other than the muffler, all the mods were done by the previous owner. Also, when I got the kart, it ran fine before and after the muffler installation.
About a week ago I made the mistake of putting some bad gas in it. It ran roughly for a little while after that but soon it wouldn’t run or start at all. So after realizing the gas I was using was bad I drained the tank and stripped the carb and cleaned it out throughly. The main jet seemed okay but the emulsion tube had a little gunk in it. It was at this point I realized this was the stock emulsion tube and it is to my understanding when people modify these engines and put pod filters on, they increase jet size and use different emulsion tubes. I’m not sure if the main jet is stock, it’s hard to tell the difference in a .28 and .36 main jet just by looking at it without any reference. Regardless, I slapped everything together, put in some clean, fresh 100% gas, no ethanol, in the tank, and tried to start, but nothing. Pulled the spark plug and noticed it was the high performance autolite plug but was covered in carbon and not making spark. Due to the carbon on the spark plug, I decided to pull the cylinder head and check out the cylinder and valves. The carbon build up was pretty significant. I cleaned it out and went to the auto parts store and picked up a new NGK plug. Side note, I think the bad gas clogged the emulsion tube and caused the engine to run very rich and hence the carbon build up, hopefully that is the end of the story with the carbon build up.... but adding this info just in case it is related.
So that brings me to today. The engine will start but only if the choke is set just right which is just barely open. And I mean barely. Open it just a little more and the engine dies. But it’ll sit there and idle just fine all day. If I touch the throttle, engine dies. Unless I open the choke at the same time as I press the throttle. Then it goes like **** until I let go of the throttle and come to a stop and the engine dies because the choke is wide open.
Some things to note that I have noticed currently:
-the mixture screw does absolutely nothing. While the engine is idling, I can turn it all the way in or all the way out, the engine runs the same. This seems odd to me and I don’t know what it means. It is currently set at 1.5 turns out as a default.
-sometimes, not all the time, when I pull the cord to start the engine, it goes very stiff randomly and without warning. The handle gets ripped out of my hand and results in a lot of pain and cursing... If I have a firm grip on the handle and don’t let it slip out, I can literally drag the kart across the garage with the pull cord if it has gone stiff like this. This only happens about once every three pulls. This is definitely not normal and I also don’t know what this means. Also, there is no knocking in the engine when it is running so it’s not like the spark plug is hitting the cylinder.
-letting the engine warm up fully does not affect the engine dying. Also, the oil is fresh and oil level is good.
Sorry for the huge post. I am just baffled as to what is going on and thought the recent events might be important. Any help is greatly appreciated.
