Predator 212cc engine troubles
Biggamefish
Ny
I have a new predator 212cc engine, runs great still breaking it in. If I am running it on rough ground and turn hard she will shut off on me. I slammed on the breaks to spin the kart around and same thing engine died. It will start right back up one pull seconds later. Is this due to the oil sloshing around and making the low oil cut off happen? Is there anything I can do about it?
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
Yeah, its the low oil sensor. You're going to need to disconnect the sensor. There is a cluster of wires in the front of the block. I think that you can disconnect the oil sensor from there.
DONT CUT... just unplug... yes its that easy....
Cover up the socket on the relay side, so as to not allow it to touch ground(the motor)....
