Relativity
This is an update for my Predator #1 engine build up. Part #69727
-Progress so far.
Disassembly of new engine. Including removing everything except block housing casing bearing and coil.
Installed complete Predator Loncin Model 210FA piston and ARC 6252 rod assembly.
Wore my rubber gloves, used lint free towels, and used Lucas Oil 10152 Assembly Lube.
Careful to keep work area clean, inside of block clean, as well to the rotating assembly with just enough lube.
Feel good about my work tonight. Tomorrow is another day and maybe will work on it again then.
Before wrapping up work tonight I measured the take out cam shaft ends and compared it the MOD2 Grind, Predator Core Dyno Cams ends. Both measured right at .55 inch.
I had one thought of the work done today. When rotating the assembly I was truely expecting the piston to go to the very top of the deck. My opinion it looked still about .002 from TDC. I will measure it later to know for sure.
-Progress so far.
