I thought I did, earlier in this post Rat posted a link for the dover coil I bought from this seller, and I saw he's also selling all the other stuff I need so I ordered it all from him....I already drilled one valve body to 5.4mm and I will order a 5.5 ream. I'm not doing the drilling and reaming free hand, I'm a mechanical engineer and we have a milling machine at work....I am guessing what you posted is your communication with the vendor. You said somewhere that you have 1 to 1 shaft rockers. Are they champion brand, or the Chinese imitation knock off. The reason I ask is because I run champions on 3 of my engines. They are great. They do not fit under a stock rocker cover. Offering you a 2nd gasket to supposedly gain clearance doesn't sound like enough. You can cut out the baffle in the stock cover. You can purchase a spacer to lift up the cover, or you can purchase an billet aluminum cover that is tall enough.
As I said in post #36, you should be buying your parts from legitimate kart supply shops.
about the rocker, If it won't fit.....
