Hello everyone I have been working on a project for some time that is a predator 212 swapped yamaha yl2. The bike is a joy to ride but it has had lots of reliability issues over the 6 months ive been riding it. The first issue I encountered was with the engine completely stock. When I would start getting on the throttle it would perform normally up until about 3/4 throttle then it would start sputtering or die but sometimes it would successfully go full throttle. This wasnt the biggest deal but it was strange. Next I did a carb cleaning to make sure there wasnt anything in there that wasnt supposed to be and I put it back on it still did the same thing so I ignored the issue. Then another issue started happening where it would run well off choke for about 10 minutes then it would start but not take any throttle at all without dying unless I put the choke on which would cause it to run poorly. At this point I checked my spark becuause I had damaged the wire on install and the spark seemed very consistent and the plug was clean. I decided that it was most likely the carb so I bought a mikuni 22mm carb and put it on with a go power sports intake. Upon putting the new carb on it ran much better and I liked it alot but it still wouldnt take full throttle without dying. Once again I ignored that and took it for some test riding but after 30 minutes the engine completely flooded out and would not start. I then started with carb adjustment and tried all of the bottom half notches on the needle valve all getting the same result. I noticed that it would flood out either after a certain amount of time or it I pushed it to full throttle and then slowed down. After flooding out this time I checked the plug and it was very fouled. After each flooding I cleaned the plug but It would continue to flood no matter what carb setting I was on. My only thought now is that maybe because of the stuck clutch on the bike it is flooding because it is being spun while slowing down more than normal maybe? Does anyone else have experience with this issue or any ideas that I could try?
I just checked out your bike, I like it!
