72/10 ratio for that heavy roller, but #41 chain...
You won't have any trouble finding a 10-tooth with the right bore for your TAV, or a 72-tooth for the rear, just wondering how the rear sprocket will mount to your motorcycle rim. Just make sure to use the bigger #41 chain and sprockets from the start. I made the #35 mistake, and have to redo everything in #41. Read my post "To #35 or knot....."
---------- Post added at 06:18 PM ---------- Previous post was at 06:09 PM ----------
Remember that a TAV feels like you're putting on the brakes when the throttle is let off, and applies a high power ratio when starting up. That's a lot of flapping up and down for the chain, and if you don't use a spring loaded chain tensioner with good travel on it, and keep the chain adjusted firmly with only an inch of free play, and lubed up every time you ride, you'll never be happy. And use #41 chain (1/2" instead of the #35's links of 3/8").
