FHB is right. It is going to get expensive, but Santa is coming...
Things you've got going....
Looks like you ordered a Hemi kit, so I assume you have a Hemi.
-You've got a flattop piston. Better for compression and combustion than the dished piston.
-You've got a billet flywheel.
-Your ARC flywheel has 32 BTDC ignition timing built in. (Most performance cams, including your cheater cam, want 32 BTDC ignition timing.)
You'v got SS valves and performance keepers/retainers.
Issues I see.....
-You want 8000+ RPM, your camshaft is for 7000+. It is a cheater cam. Stock lift, extra duration. Isky makes a 8000+ cam called a Black Mamba Sr. It will have both extra lift and extra duration. You could use some 1.2 Ratio Rockers to give the MOD2 cam some extra top end kick. These are expensive.
-Your springs are 26lbs, your camshaft asks for 18lb springs. (This should be OK I think, but I'd call Dynocams and ask them to be sure)
-Your billet connecting rod is stock length, which probably leaves your piston about 0.025" below the deck surface. A +0.020" Rod might work better, but you need to measure where the stock length rod puts your piston at TDC. Or You could get the block milled shorter so the piston sits flush at TDC. You are going to want as much compression as your fuel choice allows. Maybe 10:1 or 11:1 on pump gas???? Maybe 13:1 or 14:1 on some higher octane racing stuff??
-The carb that came with the kit may be too small for 8-9k RPM??? I Don't Know???? It is probably good for 7k, because it came with a 7k cam, but may not be big enough for many more RPM.
Things I'd do.....
Mill the head for more compression. I think 0.037" off my head brought it to 18cc. Like mentioned before... Mill As much as your fuel octane allows, but also need to consider piston to valve clearances. Maybe 0.050" Intake valve to piston clearance and 0.065 Exhaust valve to piston clearance.
-Port and Polish the head for improved flow. Might need to hog it out a bit for 9000 RPM?
-Like FHB said might be best to buy a race ready big valve head (already milled and ported)!
Use a thinner gasket. As thin as fuel octane allows, keeping in mind the piston to valve clearance and also keeping 0.020" minimum between the piston and cylinder head. (If your piston is flush with the deck, you need 0.020" of gasket. If your piston is 0.021" below the deck, you can use a 0.009" gasket.
Cut to length Cr Mo PushRods and billet lifters. Need to size the pushrods after head / block is cut and cam / rockers installed.
Head stud kit instead of the stock head bolts.
Side cover stud kit instead of the stock side cover bolts.
I don't really know what a torque plate does, but I want one.
Maybe a 3D Manual Clutch.
---------- Post added at 11:16 PM ---------- Previous post was at 10:50 PM ----------
BUT FIRST..... build the engine with the parts you have (if Dyncocams says the springs are ok) and see if you like it. If then you want more.... THEN proceed to the next phase of the build.
---------- Post added at 11:17 PM ---------- Previous post was at 11:16 PM ----------
Now since you did so well on your first post. Let's see a picture of that chassis you built. Weight, Tire Size, Gearing, and Track type (where you drive) all play important roles in go kart engine design. There is no changing gears to stay in the power band. For instance, with your tire size and gear ratio.... How fast will 9000 RPM be???
