Predator 212 build help!
matiask1
Santiago,chile
Hello guys,
Im quite new at making performance engines so I need your help untill now I want to rev 8000 rpms on hemi mounted on a race kart so my plan is to buy:
Black mamba cam for hemi
.020 arc billet rod
Performance air filer and exhaust
14 cc hi comp head ported and 0.10 milled
Dont know what valve size?
Arc ultra light flywheel
http://www.arcracing.com/dj-2227-625-clone-carburetor-for-gas/ 625 carb is that enough or
A bigger one?
performance rocker arms 1:1or1:2 ?
26 lbs springs and performance retainers
Chromeoly push rods
Racing sparkplug
Fuel pump and top plate 9:1 ,11:1 what size should I take ?
So thats my plan please answer my questions AND FEEL FREE TO CHANGE PARTS on thr setup thanks.
Flyinhillbilly
The great cornholio
North West Arkansas
If you want it to turn that many RPM then get ready to spend some money.
Personally I'd do this
+.020 ARC rod
Ported big valve 14cc clone head W/ springs, retainers, and rockers suited for 8-9000rpm. Probably best sourced from a professional builder
Forged Flat top @ zero deck height
Billet ultralight flywheel
Whatever cam is recommended by the engine builder that you got your head from.
.018 head gasket
Alcohol Tillotson
Better crank bearings
Proper rod clearance
That should be a beast in my opinion, and should meet your goals. Those kinds of RPM's are no joke, and there's a lot more to building an engine like you're talking about than just bolting parts together.
I say go for it. Take your time though. Listen to the guys here and your other Friends and acquaintances.
Are you 14 or you just have the doubts of a 14 yr old?
I have been told by guy I act like a 14yr old. LOL
:welcome2:
Staff Murderator
I think you should have started with a more robust Honda GX 200 or maybe even a Briggs Animal. I really wonder about the life expectancy of a Predator at those kind of revs...but if you replace all the moving parts on a Predator, how can you go wrong?
Speed is just a question of money--how fast do you want to go?
FHB is right. It is going to get expensive, but Santa is coming...
Things you've got going....
Looks like you ordered a Hemi kit, so I assume you have a Hemi.
-You've got a flattop piston. Better for compression and combustion than the dished piston.
-You've got a billet flywheel.
-Your ARC flywheel has 32 BTDC ignition timing built in. (Most performance cams, including your cheater cam, want 32 BTDC ignition timing.)
You'v got SS valves and performance keepers/retainers.
Issues I see.....
-You want 8000+ RPM, your camshaft is for 7000+. It is a cheater cam. Stock lift, extra duration. Isky makes a 8000+ cam called a Black Mamba Sr. It will have both extra lift and extra duration. You could use some 1.2 Ratio Rockers to give the MOD2 cam some extra top end kick. These are expensive.
-Your springs are 26lbs, your camshaft asks for 18lb springs. (This should be OK I think, but I'd call Dynocams and ask them to be sure)
-Your billet connecting rod is stock length, which probably leaves your piston about 0.025" below the deck surface. A +0.020" Rod might work better, but you need to measure where the stock length rod puts your piston at TDC. Or You could get the block milled shorter so the piston sits flush at TDC. You are going to want as much compression as your fuel choice allows. Maybe 10:1 or 11:1 on pump gas???? Maybe 13:1 or 14:1 on some higher octane racing stuff??
-The carb that came with the kit may be too small for 8-9k RPM??? I Don't Know???? It is probably good for 7k, because it came with a 7k cam, but may not be big enough for many more RPM.
Things I'd do.....
Mill the head for more compression. I think 0.037" off my head brought it to 18cc. Like mentioned before... Mill As much as your fuel octane allows, but also need to consider piston to valve clearances. Maybe 0.050" Intake valve to piston clearance and 0.065 Exhaust valve to piston clearance.
-Port and Polish the head for improved flow. Might need to hog it out a bit for 9000 RPM?
-Like FHB said might be best to buy a race ready big valve head (already milled and ported)!
Use a thinner gasket. As thin as fuel octane allows, keeping in mind the piston to valve clearance and also keeping 0.020" minimum between the piston and cylinder head. (If your piston is flush with the deck, you need 0.020" of gasket. If your piston is 0.021" below the deck, you can use a 0.009" gasket.
Cut to length Cr Mo PushRods and billet lifters. Need to size the pushrods after head / block is cut and cam / rockers installed.
Head stud kit instead of the stock head bolts.
Side cover stud kit instead of the stock side cover bolts.
I don't really know what a torque plate does, but I want one.
Maybe a 3D Manual Clutch.
---------- Post added at 11:16 PM ---------- Previous post was at 10:50 PM ----------
BUT FIRST..... build the engine with the parts you have (if Dyncocams says the springs are ok) and see if you like it. If then you want more.... THEN proceed to the next phase of the build.
---------- Post added at 11:17 PM ---------- Previous post was at 11:16 PM ----------
Now since you did so well on your first post. Let's see a picture of that chassis you built. Weight, Tire Size, Gearing, and Track type (where you drive) all play important roles in go kart engine design. There is no changing gears to stay in the power band. For instance, with your tire size and gear ratio.... How fast will 9000 RPM be???
matiask1
Santiago,chile
:welcome2:
Im actually 14 but im really good at tgis and understand most of this.
---------- Post added at 03:49 AM ---------- Previous post was at 03:38 AM ----------
Im posting pictures tomorrow im out of the city and im not going to hit those rpm, today I did talk with an engine engineer and with that rpms alot of different stuff can go wrong so im just going to keep it to a max of 7500 and normaly just 7000 but I still want to buy a nrracing 14cc head and the arc rod with performance cam lifter rocker arms and maybe a carb and the high compression gasket.
---------- Post added at 03:55 AM ---------- Previous post was at 03:49 AM ----------
Also im 14 but really capable and bored of ps4 so I got time
---------- Post added at 04:27 AM ---------- Previous post was at 03:55 AM ----------
So if someone could help me reach those rpms safely
And to not buy unnecessary parts and what milling should I choose
matiask1
Santiago,chile
hemi performance orientation needed
Hello fellow gokart minibike builders
I need your help on a predator hemi build .
I want to ride at a max of 8000 rpms on a race kart so I need you to get me there in one piece hopefully without a flywheel fin in stuck in my back
So my plan is to buy:
Performance air filter and exhaust with muffler
A billet flywheel
A carb
A billet rod
Cromeoly push rods
Billet lifter valves
Performance cam
And a 14 cc hi comp head ported and with perfirmance valves and rocker arm
So please help
My "plan" is to buy
Black mamba cam
+20 arc rod
Flywheel I dont know
CARB dont know
Head dont know
So please help me im quite NEW to building performance engines :cheers2:
matiask1
Santiago,chile
I change the direction of my build and no one answer me back the last question.
---------- Post added at 07:20 PM ---------- Previous post was at 07:18 PM ----------
so if someone could help now that I got even more confused with the head stuff
We were helping you on your other thread. You're wanting answers to alot of work that needs to be done. Ask specific questions and we'll help you along.
BUT you have to learn it as you go.
Teach a man to fish........
