Power loss
fowler
Bullsbrook West Aus
got the ring bit
but the moffler never touches the caby
a gasket is a peice of speical card board that are used in a few places
they act as seal
red means the gasket that seals the head to block joint
A gasket is a seal between two stationary parts.
A seal is between a stationary part and a moving part.
Gaskets aren't just comprised of cardboard, many different materials are used depending on application. Cork, copper, steel, aluminum, asbestos (and less lethal substitutes), rubber, composites, laminates and many more. Seals are usually synthetic rubbers and substitutes.
fowler
Bullsbrook West Aus
i was using seal in a general term
also if a seal is between a moving part the what in my tupper ware
a rubber gaskets?
i knew about metal gaskets but i was scaping the surface
doing a quick 18 word sumerey
i could write an essay but that would be too boring
i have to admit i only knew about metal and cardboard
what is a cork gasket for?
sexyvicta
same as using any other material. Used to be pretty common. Not so much now. My friend recently fitted a cork head gasket to his daewoo:eek:
edit: i was like wtf!!!!!!! when i saw it
and i dont get this. What about o-rings on a carb etc? they are a seal. Anything that forms a seal between to things(moving or otherwise) could be called a seal. A gasket is a seal
These were the basic definitions as taught to me many moons ago. Regarding the carb o-rings, you could argue that the mixture screw is a moving part. Or you could argue that the o-ring is in fact, a gasket. O-rings are often used as gaskets. O-rings are often used as seals. O-rings are O-rings.
How do you know someone is truly bored? The great gasket VS seal debate!
sexyvicta
