element10554
ah ha I forget that subaru makes more than just cars
No, the gasoline is what's flammable. Please see above explanation.And this, from Wiki-
"Octane rating does not relate to the energy content of the fuel (see heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where the octane number is raised by blending in ethanol, energy content per volume is reduced."
I don't proclaim brilliance either, but the above is quite true. Gasoline is gasoline. With no additives, it would burn like a demon. These various additives give it "desirable" properties. Again, the octane rating essentially is a stability rating. Higher octane rating does NOT mean "burns better".
If you're going to rebuilt it, get the service manual. There is way too much info you're missing without it. Clearances, dimensional specs, torque specs...
Check shaft dimensions. I recently had a customer bring one in for repair and I noted that it had a stubby shaft and was unusable "as is" for powering anything else.I could have the 5.5hp honda gx 160 off the pressure washer in the garage
Loctite blue #242 works wonders.I have to constantly check the bolt to make sure it doesnt come loose and lose my TC.
Perhaps. I rarely use the stuff unless I have an usual problem. I was always losing set screws on axle and sprocket hubs. No longer a problem.Maybe I'm just special...
Its been that way in NC & VA. I hate the stuff.
Just think of octane rating as the fuels resistance to knock. No need to get any more technical. I agree that hi octane fuel is a complete waste of money on an industrial engine. Unless you significantly raise the compression ratio or add a turbo haha
unrelated-ish: ive also noticed that when using hi octane fuel on my echo twostrokes i seem to get vapour lock(or something with the same symptoms) in hot conditions.
im no scientist but it dosent happen with low octane. No idea why. Any scientists?
either way i see no improvement from using higher octane fuel.
I have not tried an ethanol/bio fuel blend but i have heard that it can do bad things to rubber seals etc so i stay away.
