possible solution for vertical shaft motors.
sc300fivespd
hey every one, i read about alot of people trying to use vertical engines, and not alot of success stories. so i was thinking, how about a variation of this, just as an idea found a simple picture just so you guys know what what im talking about when im talking about it.
so basically putting a clutch on the vertical shaft and having it contact the sprocket on the live axle to form a 90 degree transfer of power. maybe regrinding the gears to have better contact?:bannana: :arf: :rolleyes3: :thumbsup: :toetap05: :wai:
what you guys think?
skid20
Universal Remonster
St. Louis
unless you have the gears to do that it'll more than likely cost more than getting a horizontal shaft engine.
As for using a sprocket for a mitered gear it won't work the teeth are too far apart and they will slam into each other and destroy the teeth.
TOO FAST
Canada
Vertical engine interests me too because you could build a really
low profile center of gravity kart. You can find these gears or gearboxes (angle drives) on old 3 pt hitch mowers, snowblowers,
augers etc. You could also grab the gears out of an old car diff and make a bracket for them. That's what that pic looks like its made from
t0x1k
Vroom
South, NJ
What about a differential from a some small RWD with independent rear suspension?
Mount it up to a clutch and to the shaft of the engine.
Instant differential and motor.
motor_head
expert garbage picker
sutherland IA
augers etc.
i have thought about that but i dont know how well the y would hold up to the higher rpm considering most run at 540rpm some 1000rpm and most motors run 3600rpm
TOO FAST
Canada
Yeah good point, I guess it would have to be placed so it runs
the axle, most axles turn less than 500 rpm
572bigblock
I found a small little gearbox on a Massey lawn tractor. It has the beveled gears like you've got above for running the mower blades, has a built-in gear reduction, and comes in a very small (but heavy) fully enclosed box. The box is thick cast iron, though, and if it were shaved down some, alot of weight would be taken off. i've thought about it, but its another issue on how to hook it up, how to mount it, and its a lot of extra weight.
Kaptain Krunch
Pro Junk Collector
vermont
Not if your looking to go more than 10mph, 65 is also way too much. For the most part that may work but the shifting mechanism in that type of transmission is very weak and will most likely give way pretty quickly. For 65 you could easily just get a RAGB
freakboy
the names 'mater
hick town
try using some spiders from a rear end from a car. my freind is thinkin of givin me his rusty nova 10 bolt to rip them out and try to make one. im considering sayin screw the mower and putting the engine in my gokart.
Rotore
Teh SPIK
Caguas, Puerto Rico
yea thats the easy route. or rip the engine apart and mod it like i did.
#28 FASTGRASS
Adelaide Hills, Australia
Outboard leg
Anyone thought of trying the gearbox at the end of an old out board leg, off a 10-20HP? got reverse too...fully enclosed running in light gear oil as well, would have to be pretty bullet proof?
Thoughts?
:popcorn:
Odonnellp24
Ludicrous Maximus
South Texas
If you are dead set on a vertical shaft configuration look at the drivetrains in most riding lawn mowers. Talk to some folks who race them and they will know what's best to use as far as trannys and ragb's and such. However it's much more cost effective to just get a horizontal shaft motor.
#28 FASTGRASS
unless its 4-stroke then its not practical
Errr, sorry B man you've lost me there...:huh:
Odonnellp24: However it's much more cost effective to just get a horizontal shaft motor.
:iagree: and easier too, but it expands (or implodes in the brain) coming up with ways of thinking "out side of the square"
Well worn Quotes: "Necessity is the mother of invention" and "Solving one problem creates at least two others":rolleyes3:
fowler
Bullsbrook West Aus
Thoughts?
:popcorn:
now thats a good idea
but how would the gear box hanlde the touque changes produced with a land vehical
