please read this
sayre315
Rupp enduro
Oklahoma
ok heres a realy stupid question that only i dont know lol. im cleaning my 2cycle 31cc ryobe and was wandering if i ould use carb cleaner to clean the inside?
oscaryu1
Soak it in SeaFoam for a week. Worked wonders. I had a 25cc I WAS working on. The rings broke, and I didn't want to spend $10 on one ring, so now the parts are all over the place. However, the carburetor looked like new after the dip in SeaFoam. Like literally new, inside out.
Remove the primer however, before I dipped it in SeaFoam, it worked fine. When removed, there were cracks everywhere, and simply fell apart when pushed. Another reason why I didn't try and fix it.
Pyrotechnic
If you added seafoam to the fuel, yeah I could see that being very bad for a 2 stroke. If you took off the air filter and used a spray bottle to spray a fine mist into the carb while revving it, I should work just fine.
sayre315
Rupp enduro
Oklahoma
i took it all apart so that i know that im only getting the parts i want wet
so can i clean the piston, head , crank and crank case thing?
oscaryu1
Don't use force. I personally don't have any experience with 2 strokes, but on everything, forcing it to come out doesn't lead to positive results.
Anywho... if you can't get it out, leave it in. It's not that important, if everything else is fine.
Kenny_McCormic
Kartless....
Michigan Troll
Bad idea. This is a 2 stroke, you'd be leaning the mixture, and who knows what.
Yes I know its a 2 stroke, the problem with running lean is it overheats and melts the motor, your not gonna run it for more than a minute on the seafoam+it will have to be choked while the sea foam runs through the engine to keep it from dieing anyways. engine probably takes more damage form surge tuning the carb.
oscaryu1
Better safe than sorry.
To remove carbon, use Techron Fuel System Cleaner. 50% if I remember correctly. Carbon will start dripping out of the muffler. Don't rev it, or it'll come in chunks. Then you have another problem to deal with.
