please details on how to put the back tire up
nawizzel15
hi so i started building a mini chopper in my metals class pretty cool but i really need some help since im a beginer at this **** well im a the step where im ganna weld the back part on that connects to the set and the bottom of the bike the part that kind of looks like a U well wut i want to kno is i dont under stand how to set up the axel and the tire like do i just make an axel and then how do i put the tire on so that it isnt sliding around and what do i attach the sprocket on im really confused about this idk if i explained it well but if u need details to help me out please ask
im going to make the back where the axel is put in like this bike http://www.westcoastminichoppers.com/images/Img13.gif with that triangle in the back
nawizzel15
why i can make all of the metal things i have access to free metal and tools i just need to kno wut i need to make and the stuff i cant ill buy but i just want to kno wut i need please
RobertD
Administrator
Texas
Use some punctuation! And welcome to the site. I like your commitment to building stuff!
nawizzel15
ok let me reword everything i need to kno how to set up the rear tire? as in wut else do i need besides a tire and an axel? wut do i need to attach the sprocket to? wut im trying to ask is if i were to buy a kit of this wut would the parts be to set up the back tire because i can build and machine all of this in school. which is why i want make it not buy it more fun to. heres a picture by the way
http://tinypic.com/view.php?pic=34ilpom&s=3
and as a side note how will length of chain effect anything?
jr dragster T
Cold place
well generally speaking a long chain wont affect much but use common sence its a mechanical part of a machine it takes horsepower to move every single link on that chain. And if your chain is too long you will need a chain tensioner but lets not go there yet.
jr dragster T
Cold place
I saw a tire, brake, sprocket. assembly for sale on the internet somwhere you could look for and purchase in my opinion it makes everything alot easier. Because its all assebled for you and the wheel includes bearings so you dont need to run bearings on your bike frame so that imiminates the need for a rotating axle.
Mud Pup
Florida
I'll try to help, but please concentrate on using sentences. Damn!
The picture you referenced is a live axle. You'll need an axle (with a keyway) that is the same size as your bearings and your hub. This is typically 1". You'll need to match the sprocket and brake rotor to that size axle. Use locking collars to keep everything where it needs to be.
