Well more thought has gone into this kart with the arrival of the silver fox . Starting to drift from the one link/panhard bar idea because of unneeded complexity and weight, besides sourcing expandable u joints or cvs at this scale is difficult and the ones I can find are expensive. So the new idea is a swing-axle sus. What if I put the axle on a single hinge pin to swing on, this would facilitate tons of travel, and minimum cost, weight, and complexity. This hinge point would also be the Drive Shaft, meaning that the DS and the axle hinge rotate about the same axis. I do realize the massive camber changes the wheel experiences throughout travel, more than a link sus. The also major setback is that the sus. cannot "bump" all together, like if the kart went over a speed bump straight on, the sus. could do nothing because it would not activate the swing hinge pin (DS). You could straddle the speed bump and activate the sus. The last problem would be the twist when the DS is turning, its going to cause the axle to want to turn on that same axis, I think this can be solved with shock tuning.
If anyone is familiar with the euro trucks Tatra, they have a sort of similar setup where the axle half shafts rotate on the same axis as the DS.
Can anyone see why this would/wouldn't work?
Backbone
