ok so I know two projects at once = twice the fun
still, won't be starting this until mid june
the plan:
1 use the 5hp tecumseh off a snowblower (4th pic)
2 full time 4x4 with single DS running the length of the kart
3 engine mounted transversely, using either torque converter or centrifugal clutch
4 double wishbone independent suspension at each wheel
5 use of snowblower/auger worm gear box for each axle (IK that the gears will shear under the load so they will be swapped)(3rd pic)
6 a lot of sus. travel (shootin for 20ish" shocks)
7 geared LOW (this machine is not intended to be a fast offroader in any way, more trials, etc)
the immediate issues:
1 coupling the main DS to the snowblower gearboxes input (shaft adapter, etc)
2 coupling u joints to snowblower gearbox outputs and to hubs
3 the u-joints (not a common item at this "scale") still, have found a couple suppliers, another u joint issue is that with parallelogram suspensions, the axle decreases in length significantly when the suspension flexes, meaning the joints will have to be splined or in some other way expandable/collapse-able
4 there is going to have to be bearings all over this thing to hold the DS + axles in place
5 engine lacking power
other project plan info:
Frame material: 1”ODx.065”DOM,
Frame rectangular dimensions: 78"x 17"
Suspension Arms: 1”ODx.120” DOM
Suspension type: equal-length double wishbones, parallelogram style
Steering mechanism: with the shafts, etc being the way, a bell crank steering will be used, putting the tie rods above the drive-train components (if this doesnt have enough steering torque, a rack and pinion will replace it)
Tire size: 13"
Approximate cost: $2500
looking for insight regarding "immediate issues" as well as any other observations for the kart
so I will attach a couple pics of the rough design, sorry still using sketchup, note the shocks are not yet in the design nor are the axles/DS
and a still "rough" parts list
this gearbox is a 1:10, great for trailing
5hp, 1" bore crank stepped down to 7/8"at end (this engine has no air cleaner, but electric start!)
finally incomplete parts list
the plan:
Tire size: 13"
