it seems we may be saying the same things, just with different wording. if you take a 80cc engine and remove the tranny gears running the output directly from the clutch hub, you will have a nice amount of torque, no speed to speak of. now if you put the gears back in and utilize the normal output shaft, you may get better or worse torque, but your topend speed (depending on gearing and amount of gears) will be x times more than the previous setup.
