Here's my experience with dealers/service places... just a warning, it's a bit of a rant and goes off topic at some points too, so no need to read if you don't feel like it. Also, this is just my experience with a single person... there are many more, all but one bad, but this guy takes the cake:
My dad has a 'guy' (at a dealership) that my family takes all of our cars to and always get suckered into buying things. My dad kinda has the "Ohhhh this guy is finding things wrong with the car and keeping us safe" kinda mindset, I guess. At one point the minivan (which is 'mine' (I'm sure we all know how that goes) now, but wasn't at the time) got a clogged fuel filter. Car wouldn't start until you cycled the fuel pump on and off a few times, it'd run for a bit, stall out again... classic clogged filter. I was driving it at the time, and by the time I had gotten it home the problem seemed to have resolved itself. Parents still wanted to take it to the shop, and my mom even said the check engine light turned off as she was driving to the shop, yet the mechanic still somehow managed to pull trouble codes from it, and said the 'computer' and the camshaft position sensor needed to be replaced. They charged $500 for the 'computer', and $30ish for the sensor. Total bill was $2000, so I guess the 'labor' was through the roof as well. Anyways, I checked it out later... none of the control boxes (what I call the ECU, cabin computer, etc) had been replaced, as evidenced by the undisturbed dust/particles on them and their connectors. Also, the gas tank was nearly empty, after it was taken in with a half tank. So maybe they changed the fuel pump (which has the filter built in) in which case the missing fuel would be acceptable, had they said something about checking/changing/whatevering it, however, they didn't, and that's 200 miles worth of gas. Completely unacceptable.
Next up came the oil change. I was going to do it myself. I got the car jacked up, warmed up, and I had a pot under the oil pan. I put my socket wrench onto the plug, and it wouldn't move. So, I moved up to my 10" vice grip monkey wrench (like a monkey wrench but the jaw clamps down... essentially gives you a perfectly sized wrench, which I had personally tested another one to the point of failure to confirm that the jaws will not spread)... still can't turn it, and can't fit a breaker bar down there. So, I leave the wrench clamped to the plug, about perpendicular with the ground, tie paracord to the loop on the end of the handle, go to the side of the car, and pull (and yes, I was trying to turn in the correct direction). When I got to what would be my estimate of somewhere around 100 lbs of force on it, the wrench turned, and I fell on my back end. Like I said, the wrench turned. I went back under the car, and attempted to turn it by hand, and it still wouldn't budge. I pulled the wrench off. While the wrench had turned, the plug had not, and replacing two corners of the plug head were corners round enough you could swear were meant to be that way, save for the top of the head bulging outwards and the shiny finish. At this point I agreed to let my dad take it to the dealership if he did two things: ask him if the plug was on there very tight, and have him hand tighten it when replacing it. Naturally, my dad didn't ask him to hand tighten it, however did ask if it was on there tight, and what he used to get it off. His responses: "no" and "monkey wrench".
Number three: Car went in for tires. Mount, balance, all that good stuff. Long story short: Steering knuckle, or whatever it is that aligns the knuckle is damaged, and now the car pulls left... not horribly, but still requires an annoying (and tiring over time) amount of force to on the wheel to keep the car going straight. The mechanic said (more like blamed it on) it was because you couldn't adjust the toe angle... which is true, but wouldn't need adjusting had the knuckle not been damaged.
And just to gripe, all this stacks onto the fact that I'm a fairly new driver (~2 years, been driving on a regular basis for less than 1) in a minivan (horrible acceleration (think merging), spotty brake booster, and the horrendous handling every minivan entails, not to mention getting blown around by wind) so when you throw in the car actively fighting you to pull into incoming traffic with both sides running at 65-80mph... not to sound ungrateful, I mean... well it's not really mine but I didn't pay for it, and my parents help a bit with insurance... but I'm just not happy with it.
Anyways, needless to say, the minivan doesn't go there anymore. To date, I've needed to change the serp. belt, water pump, and idler pulley, flushed the radiator, changed the radiator hoses, and spark plugs (copper ones which looked at least 50k miles old, friend who works on cars said they were the worst he'd ever seen), replaced the instrument cluster (tach motor burned out, parents blamed me, otherwise I wouldn't have bothered), and done the routine maintenance. Yes, all that in less than a year. It wasn't taken good care of, but it seems to be running well now. Just out of curiosity, I got a quote for that and it came out to around $1000 parts, $5000 labor. I paid about $200 and did it all myself in about 5 hours. It still needs a new brake booster, but I don't feel comfortable working on the brakes, and nowhere around here has given me an anywhere near affordable price. E-brake still works though. So yeah, at least in my experience, maintenance shops = run/drive away as fast as you can.
