pictures / help part 2
willsie
the axle keeps getting bent
lemegacool
got boost? :)
quebec canada
lol i was looking at the pic and was like: hmmm the shaft looks bent...
install a pivot (two pillow block bearings) right behind the seat then run two shocks each side of the rear frame - done!
Buick455
got any pictures of it?
Florida
i had the same problem with my axel, i added a 3rd pillow block to the center and it hasnt happened since :cheers2:
willsie
shocks
is there a certain place that the pivot point has to be in relation to the angle of the shocks?
if i got some motor cycle shocks what would be the distance of travel they would have say on 13 1/2up to 16" ones?
willsie
the axle always bends out toward the wheel. i have 2 pillow blocks for each wheel. would one inthe center really help that much?
Kaptain Krunch
Pro Junk Collector
vermont
the second pillow block on each side doesnt look very well mounted (no offense). I would suggest simply taking the two outer pillow blocks and mounting them in the center. Also, maybe a thicker axle would solve your problem, looks like yours is 3/4"?
theo
Mounting the shocks depends on the stiffness and length of them. Best thing to do is build the swing arm and tack weld the shock mounts on and double your weight to see if it bottoms out. You don't want it too stiff because you are wasting travel. Shoot for the shocks being 80 to 90 deg. to the swing arm at full compression.
theo
lerick
heres an example of a suspension you could use
this took about 2 hours to do so i hope you like it
I'm in with Kaptain Krunch, for what it's worth. You definately need a thicker axle, with better support. I have a very heavy kart with a gx340 (big lump o' steel) and I pound the wee out of it (and myself), no suspension. Axle shows no signs of pain, it's 1 1/8". The pillow blocks are mounted solidly as far outboard as possible. Here, I dug up a pic. Cheers! Chris
theo
1" is large enough, it all depends on how you build the swing arm and how close the bearing is to the axle hub
theo :bannana:
johnmbranham
souf carolina
i decided with the 1" axle too, but i didnt set up for a jackshaft thou. i concidered it and dropped it for weight issues (frame is 1/2" black natural gas pipe) its easy to weld but alittle heavy.
johnmbranham
souf carolina
front solid, rear swing arm. leaving the option open to change the front to one a arm with shocks. but i think if i do go front suspention, ima look for some premade spindles, or make them to suit my buggy, and i will jack it up in the air. MORE ground clearance is good till ya flip it. i need a steering rack!
willsie
it is 3/4 . if i go with a larger dia. the rims accept only 3/4. expense is always an issue, i dont have much extra spending cash. if i could go to 1" and went down to 3/4 for the wheels would it be any stronger
