robin
all the mods i did to mine and it onley dose 4500rpm is that a honda clone becuse all the ones i have real hondas have ballberings on the crank shaft
yea. just heard a story. my shop teachers friend took the governor on his kart, over reved it. the engine threw a crank counterweight and went into his back.... he is now dead.
when the valves float thats a bad thing...
um no, i was stupid wen i first started put in a performance cam and didn't put in stronger springs. so it hit.
and the gov. was removed.
Peformance cams usually have higher valve lift, which means the valve can stay open with more lift during valve float, and thats why it hit your piston. Same can be true for higher ratio rocker arms.. With all stock parts, valve float wont kill the honda or the honda clone.
