Pathwinder (Predator 212) Throttle Cable/Clutch Questions
Hi All,
Doing some maintenance on another one of my son's friends go kart. This will be my 2nd one
. Looks like this one is a "Pathwinder" model with a Centrifugal Clutch vs the Manco I just rebuilt with the Torque Converter.
1) If I decide to change to TC, looks like the engine will need to be raised up significantly, so that the Driven Pulley's Sprocket would be over the live axle sprocket. I also noticed the existing brake design would also have to be changed, because the live axle sprocket would need to be shifted over. Could I just buy the jackshaft plate like the Manco had? The bolts patterns would line right up I'm sure. Otherwise I would have to get some thick metal plate and have that drilled out. Also, I honestly don't even know if I've got the room on the driver side to add a TC. That frame might be in the way.
2). Not sure of this throttle cable. Its very short and needs to be replaced....but I haven't seen this design. Was this cut short to adapt? Its not the typical design with the loop at the end, as this gas pedal doesn't have the design for that type. It operates that lever, which is attached to that spring and pulls the short cable.
So, looking for advice on a new throttle cable at best. New clutch design is not necessarily needed.
Hi All,
