Pathfinder (Predator 212) Throttle Cable/Clutch Questions
gibbywmu
Pathwinder (Predator 212) Throttle Cable/Clutch Questions
Hi All,
Doing some maintenance on another one of my son's friends go kart. This will be my 2nd one :). Looks like this one is a "Pathwinder" model with a Centrifugal Clutch vs the Manco I just rebuilt with the Torque Converter.
1) If I decide to change to TC, looks like the engine will need to be raised up significantly, so that the Driven Pulley's Sprocket would be over the live axle sprocket. I also noticed the existing brake design would also have to be changed, because the live axle sprocket would need to be shifted over. Could I just buy the jackshaft plate like the Manco had? The bolts patterns would line right up I'm sure. Otherwise I would have to get some thick metal plate and have that drilled out. Also, I honestly don't even know if I've got the room on the driver side to add a TC. That frame might be in the way.
2). Not sure of this throttle cable. Its very short and needs to be replaced....but I haven't seen this design. Was this cut short to adapt? Its not the typical design with the loop at the end, as this gas pedal doesn't have the design for that type. It operates that lever, which is attached to that spring and pulls the short cable.
So, looking for advice on a new throttle cable at best. New clutch design is not necessarily needed.
Staff Murderator
A lot of go karts have a rod and cable operated throttle (My Ken-Bar kart is like that); In other words the majority of the throttle linkage is a steel rod, and the last 1/3 or so is cable. It's rugged, designed to be idiot-proof.
Looks like where the rod ends under/behind the seat, you will need a cable clamp to mount your cable portion up to the point it attaches to your engine. EDIT-- Looks like the cable clamp is already there, hard to tell.
I'd recommend picking up some cheap bicycle brake or derailleur cable from a store and cutting it to length.
Also: plenty of videos and how-to on attaching said cables to Predator 212/Clone engines.
gibbywmu
Hellion,
Thanks again! Well there goes that idea of buying a throttle cable on Amazon to replace....like this one :(
https://www.amazon.com/Throttle-Cab...hrottle+cable&qid=1566218063&s=gateway&sr=8-4
Yes - there is a cable clamp already there.......its actually still on the cable. Not sure if I can reuse that or not? A new pic is attached of the end in question.
I know how to attach the one end to the Predator, that's easy, just was uncertain about the other end since it does have that rod end style design behind the seat.
Do you a link/pic of a cable I would need to buy and custom fit? Not exactly sure what I'm looking for............or could I just use this other cable I have pictured and cut both ends off? Only needs to be about 2ft or less in length.
Staff Murderator
Would be a shame to butcher a bona fide 71" long cable just to use 24" of it.
Maybe you're looking at the Amazon cable because you're trying to ditch the rod & cable combination and go to all cable? That would be an option....
Like I said before, I'd use bicycle brake/derailleur cable from the department store and cut a small section from it, providing of course it's not too narrow to fit your cable clamp.
If it is too narrow for your clamp, you could sleeve it at the end with shrink tubing, drinking straw or some kind of surgical tubing or tape.
EDIT--sure why not. Buy that 71" cable and use it whichever way you want.
gibbywmu
Hellion,
Went to the store and did what you said. Bought some of those bicycle cables. I cut the 1st too short (oops), and the 2nd one I had issues too. The cable clamp doesn't seem to hold the cable jacket tight enough. After some test pushes on the pedal, it slowly works it way forward......then the cable starts to get slacked up between the end of the cable and that flathead screw clamp. Its completely fine and doing its job on the throttle assembly. No issues there at all.
What am I doing wrong? Since the 2nd cable was slowly working its way forward too, I tried crimping the cable clamp. I crimped it too much, and then the cable wouldn't retract correctly so that must have damaged the outer jacket. What a pain! Definitely not a fan of this design. The Manco I rebuilt last week was much easier to replace the entire throttle cable!
I tried using one of the supplier ferrels in the bag of bicycle cables, but that didn't seem to work. Tried wrapping the end in friction tape too, but the same problem kept happening........the cable would just work its way forward and some test pushes and then it would slack up.
If not enough force on clamp - cable moves forward past cable clamp and starts to slack
If too much force - Damaged outer jacket and cable doesn't retract
Where is the happy medium at?
Staff Murderator
How about an overall photo showing the entirety of the new cable? In daylight or studio lighting? ;)
You should, ideally, have a nice, smooth arcing cable run going from the back of the seat moving up to the engine. No hard bends or kinks, and you're going to need to eliminate any excess slack in the cable for everything to work right--e.g. ensure the gas pedal is completely at rest and that the throttle lever/governor control at the engine is also closed or at "zero". Furthermore, the slightest movement of the gas pedal should reflect similar movement at the carburetor.
Re-read my post #4.
I mentioned means of making the cable fit tight in the clamp. You may even have to bend or flatten your cable clamp some so it gets a nice grip on the cable housing.
Your new cable (housing and inner twisted wire) should be slicker'n snot but take care to lube the cable with 3-In-One oil or WD-40 or something from time to time. It's a maintenance item for motorcyclists and such.
gibbywmu
Hellion,
Sorry about the pics. I took a few more for you that should be better :). This is pretty much the same "arc" for the cable as before, although that cable was very damaged as well. I think the same issue occurred over time on the previous cable...........it was moving a bit in that clamp and just got damaged.
I also eliminated all of the excess slack just like it should be. The only issue is moving in the clamp. I do have 1 more bicycle cable to try out. It came with a pack of 4 and of course I damaged 2 of them, the 3rd is what you see. Not sure if it matters if it is a shifter or braking cable, probably doesn't matter right? As long as the cable is moving freely in the cable jacket.
I've tried having the end of the cable pointed updwards, downwards, etc to see if that changes anything, but when the gas pedal is pushed, it still wants to pull that cable through the clamp.
I use brake cable as they are typically thicker than the derailleur cable...
You need to use something like what is on the brake setup on the bicycle... the ferules stop the movement of the outer sheath, slackening the effectiveness..
gibbywmu
McKutzy,
Thanks! I took the cable back off, and took one of the plastic ferrules that came in the bag and slid that over the end of the cable. Then, I used some friction tape around the end. Placed that back in the cable clamp and tightened. Retightened everything and it all seems good to go so far. Took a couple test runs, and actuated the pedal several times. Cable seems to be staying stationary in the clamp! Hopefully it stays that way!
I'm looking at getting a used Manco. Any idea how much I should be paying for a 2 seater w/ roll cage?
JTSpeedDemon
2019 Build Off Winner!
Texas
Running or not?
What kind of engine(if applicable)?
How many problems?
What brand/type?
We need a LOT more info to appraise.
Staff Murderator
...I'm looking at getting a used Manco. Any idea how much I should be paying for a 2 seater w/ roll cage?
You're gonna pay what the seller agrees with. That's what you're gonna pay
You made it sound like the kart was a "make an offer" deal and JT was ready and willing to assist you.
You hasty fella, you. :mad2: :rolleyes:
