I need to make my electric ATV run longer. It has a Lithium battery 25.2 volt 7.8 AH. Question: can I just add another Lithium battery and parallel the connections with same size and type battery?
Stephen
---------- Post added at 10:43 AM ---------- Previous post was at 10:39 AM ----------
I have an X-Pro 350watt ATV that cooked the controller Yi-Yun YK1912K 24 volt, 13 amps max replaced it with a Topro YK31C 24 volt, 500 watt 25 amp max
The ATV ran great but the motor started smoking. ATV motor is a 350 watt 24 volt, 19 amp max. I ordered a replacement 24 volt 500 watt motor BY1020D. The new motor looks more than twice the size of the original. The question is what size battery is needed now? just buy the same battery and parallel it?
My understanding is that the triad of battery-controller-motor must be balanced to work successfully for any decent amount of time.
Motor : BY1020D 24 volt 500 watt
controller: Topro YK31C 24 volt, 500 watt
Battery: 24 volt, 7.8 AmpHr X 2?
Stephen
Stephen
Stephen
