Our 17HP 200cc 5 Speed Build
Thoughts On The Build
  • Looking Cool!
    Votes: 29 96.7%
  • That's gonna break within seconds!
    Votes: 1 3.3%
  • Total voters
    30
MatthewD
Northern Ireland (UK)
Yeah well I`ve got quite a bit of Money Saved up and I think I`ll use the original motor. Just maybe lengthen it, proper steering wheel, pedals, and new seat.
Go Kart NZ
New Zealand
Ok, a little time over the weekend to start on the rear frame support, also moved the motor more towards the middle..
java230
Seattle WA
A single shock between the top and bottom loop by the engine? Look at mountain bike or snowmobile shocks/struts.
Go Kart NZ
New Zealand
Yes, already had that idea, but sounded to simple, no fun in that, but yes that is what we plan to do, will use the same shock as already used on the cart on the swing arms, will also place a 3rd one in the middle behind the seat, just because it would look good, "High Tech"
Go Kart NZ
New Zealand
Ok, had to modify the rear frame on one side to allow movement for the motor, and started fitting the rear shock connecting the two frames..
