Opposed twin, back from the dead.
BriggsTwins
Pittsburgh pa-Tallahassee- fl
they are nice engines, check your plugs, and do a one cylinder test. if the engine can run on one clyinder for over 1 minute your ok, otherwise there may be a compression issue in the block.
give the carb a scrub and make her purty
freakboy
the names 'mater
hick town
Does that thing have mufflers? if so hack them off!!!! lol the sound with strait pipes on these things are freaking sweet! yours sounds pretty smooth.
freakboy
the names 'mater
hick town
my 20 hp twin i got on my racing mower that i just got running last week that thing is awsome. the rumble these make with strait pipes is amazing.
freakboy
the names 'mater
hick town
its about the same but its got more of a lower rumble and when you rev the thing up it gets scarry!
IHcubguy
just a member
Coal City, Illinois
I have a Briggs 18hp twin and have that same problem with it starting, with a full charge, it does'nt want to turn over without messing with the switch, then it takes off with no problem! I thought the starter was weak and was the problem, 120 bucks later... samething!
BriggsTwins
Im my case its a weak battery, if i charged it she runs no problem, great engines!!!
solomon
ca
id be pist if i thought it was fine and just a weak battery and it was REALLY a sheared key.....
