Ok, question (Would greatly appreciate a tip!)
Garified
I like to move it move it
SC
Ok, so my neighbor has me working on his motor scooter. It's a MP-150 M. He basically repo'd it from his grand-daughter who neglected it. Well today I disassembled the carburetor and cleaned it all out.
After re-installing the carb, it ran great! Only problem is, at around 3500 RPM, the engine wants to bog down and stall. Same deal if you open up the throttle too quickly - It'll shut off.
But if you basically open the throttle wide open at that 3000-3500 RPM mark, it'll want to bog down THEN the engine will start hauling ***, at which point it runs great until you slow down and open the throttle again, where it does the same thing.
Any tips?
TL;DR - engine wants to bog down and cut off when you open the throttle up. What do?
oldbikerarlo
Old guy
Marana, Az.
I'm going to assume that this is a two stroke, it sounds like the low end jet is adjusted too fat. try turning it in 1/8th turn at a time. My experiance with two strokes is limited to gas RC engines, but I think the basics would be the same.
Bluethunder3320
check spark plug and post a pic. all clean and white colored means lean, all burnt and black means rich.
Garified
SC
It's a 4 stroke 150cc.
Anyway, got it idling perfect for a while. Turned it off and went to crank it back up and it takes a while to crank. It won't start without the throttle wide open and when it does start, it only runs for like 5 seconds and cuts off again.
Garified
SC
Made some adjustments - now I have it running and driving pretty good.
Only problem is, if you jerk the throttle wide open, it'll stall and shut off. If you ease it then jerk it open, it rev's fine.
Another thing is - When running down the road at full throttle, it's like the engine stutters a little, but keeps up speed. It's like it's getting a steady stream of fuel, then no fuel for like .2 seconds, then again and again. blah blah.
It got too dark for me to mess with it anymore, so I'll be back on it tomorrow.
Garified
SC
Ok guys, nevermind.
I took the carb back apart, and it turns out that the diaphragm in the top of the carb was cracked all the way through , but in a way that it wasn't noticeable by eye. I replaced the diaphragm, and the scooter runs 100% perfect now. No bogging at all.
Thanks for the replies anyway guys!
