...& now, for my next trick
... I'm going to add this:
to this:
I've had the scooter laying around for a few years, I picker it up for nothing so, it's a bit rough, but it's time to do something with it
What I've done so far.
The first thing to do was create some kind of connection between the engine & the frame; a few bits of 1" angle, enter fabroman & we have engine mounts.
Then I had to "modify" the cowling to accomodate the angle so it didnt interfere with the clutch.
A bit of work with the dremel, a rasp, file & a box cutter & we have checkouts.
Put it all together & everything fits like a glove
Looking good Fabroman. Have you seen my thread where I did a friction drive on a bicycle?
http://www.diygokarts.com/vb/showthread.php?t=14738
I have now :roflol:
I'm, sort of, going for something similar but with the engine centred to assist balance (because the engine weighs nearly as much as the scooter) It will have a chain driven shaft with a roller on the tyre so, technically, a friction drive.
The next thing to do was somehow attach a sprocket to the clutch drum. I cut the original 1/4" shaft drive off, a bit of fancy lathe work & a few small TIG welds & we have a sprocket retainer.
P.S. Yes, I will be using bicycle sprockets & chain on this project; with the limited torque of the engine, I can't see it breaking in a hurry.
P.P.S. This is not going to be a 2 week build, what with everything else I have going on ATM...
Nodroz
Belgium (Europe)
Noooooooooooooooooo! Just typed a whole reply in here and lost if by pressing a wrong button. Aaaargh!
A quick summary:
- This will be an interesting build for me, as have such an engine laying around here too waiting for a scooter.
- I've seen people on youtube removing that clutch because it was too weak. Are you sure it will handle the load?
- Did you do any cutting on the clutch? My clutch is in the begin round but then it transforms into a square with a hole in. Did you remove that part?
I HATE WHEN THAT HAPPENS! I did that just last night.
A quick summary:
No, but it's not much of a load. I'll just have to see how it goes :worried2:
Does that answer your question? :)
Si your sprocket is only being held onto the clutch with a few set screws tightened into the dimples clutch cover? Do you think that is going to hold up? I am just worried that the set screws are going to strip out of the dimples you have drilled
Hey, it works on my daughters go kart, I can't see why it won't work on this
So you bascially welded a new "axle" on that little clutch?
It looks like he just cut the square piece off.
That's correct, landuse, no welding on the clutch
