CampJeff
Hope thus is in the right place; apologies in advance if not-
Trying to soften the ride on my wife’s powerchair- and I’ve got wheels and tires, now need to connect to 25mm diameter motor shafts - photo is what i’m trying for .
On a rear hub, ( for example, 25mm X 115mm ) does the split-clamp portion fit the 25mm axle diameter? If so, and i can track down some fairly long ones - 4” or so, should work.
Thanks ahead of time - sounds like alot of knowledgeable folks here!
