Not So Mini Chopper Build
ridin_low07
Oklahoma City
This started life as a Chinese mini chopper with what I wanna say was a 49cc motor. I traded off a doodlebug for it and decided to make it something fun. I never really see anyone do anything with these so here we go.
ridin_low07
Oklahoma City
After having it for about a month or so I decided that It was gonna need a big motor if it was truly gonna be a chopper. What other way should I go besides the almighty Predator 420
ridin_low07
Oklahoma City
Only issue with the 420 is that it wouldn't fit in the frame without some modification. That brings us to our current stage. I chopped and stretched it a bit to get the 420 inside the frame rails.
I also picked up a front wheel from a Kawasaki dirt bike and a front wheel from a Kawasaki Tecate 3 wheeler. I think I am going to be changing the front wheel to a Schwinn stingray front for a little easier install. Going to have to fab a rear end to fit this huge Tecate wheel for my drive wheel.
What do you fellas think?
ridin_low07
Oklahoma City
:oops: forgot the pics
ridin_low07
Oklahoma City
Didn't like the idea of how I would have to fab a brake holder for the front end so I changed the wheel. Gotta find a set of sealed bearings that is gonna work out for me though.
ridin_low07
Oklahoma City
Well I don't seem to be getting much attention lol so lets see if this changes anything..... Got a TAV for the 420, 45th rear sprocket, 205/50r10 rear tire on a Kawasaki Tecate front wheel, Schwinn chopper 20x4.25 wheel for up front. Have mock up wheels and tires on just to see how everything was lining up.
ridin_low07
Oklahoma City
Progress So Far
B.M.800
TheBeal.
Central PA
What no V-twin?? :D :D
Is that a functional gas tank or is it fake like the baja heat/warrior mini bikes?
If it isn't functional, least it can be taken out and replaced with a custom one that will be functional. Agreed on the V-twin, or lack thereof. A Briggs and Stratton 479/16hp V-twin could fit nicely.
ridin_low07
Oklahoma City
Cant afford a V twin. I got a good deal on the 420. And yes the gas tank is functional. I have to find a gas cap for it and make a rear mount. Other than that itll do nice. I cut the axle plates back off because they were a little off centered. Gonna fab another set this weekend.
Lets keep it all in one thread please
B.M.800
TheBeal.
Central PA
Thats cool. :thumbsup:
ridin_low07
Oklahoma City
Well I have made a little more headway. I ordered a TAV setup that was advertised to work with the 420 but unfortunately it wont work. Now I am kind of stuck debating whether to just go for a clutch or save my pennies and get the GPS bolt on kit for $375. Gas tank is mounted, seat perch is built, 420 is mounted, rear tire is installed and I have my Sprocket hub situated. Need to make a holder for the rear brake drum, Spacer thingymabob for the Sprocket hub, foot brake pedal or hand lever and longer cable, mount the battery and find a fuel cap for the tank. Other than that Project Baptiste is almost ready to ride.
Scout
Nutjob
Indiana
I'd like to know more about the rear wheel setup. I'm thinking of a mini build with a wide tire like that, but i'm not sure what I'm going to do to to spin the rear. Probably gokart style axle bearings, custom wheel hub, and a sprocket hub.
Easiest is to build a live axle. You can find flanges with the right bolt pattern, to use as a hub.
My other bike(on my thread) is about the same look as this with almost the same trailer tire.
