There's a bit of confusion in this thread...
* SOME snowblowers and tillers use the camshaft PTO to achieve reverse, through a combination of belt tensioning, and/or rubber drivewheels. SOME use the disk drive described above, some use a little gearbox.
*Tecumseh L-heads are very commonly found on older Craftsman equipment. They are marked Sears or Craftsman, and have a model number unique to the OEM. The internet is loaded with cross-reference info. My faithful old Tec H60 originally came from a mid-1980's Sears snowblower - and did NOT require (or have) a camshaft PTO for reverse.
*H60's are very plentiful, if you look. If you cannot fix your engine for whatever reason, source another one. If the replacement does NOT have the camshaft PTO, then re-use your camshaft and side cover from the new engine.
