Noob Question
It is basically a switch that is activated when electricity passes through it. Can also be a controller for something mechanical.
A car's starter motor has a solenoid that when energized pushes the starter gear against the flywheel in order to turn the engine over (starting).
Bwdeaton
Dayton, Ohio
A solenoid is a remotely activated switch that allows you to use a low current circuit to engage a high current circuit without the need for expensive bigger wire and heavy switches connected to power the high current circuit.
